Fjuckar???
GubbLasse
28 Jun 2008
Ingarö, Stockholm
Honda CRF1000 Yamaha MT-09 Honda CBR900sc33 Yamaha xtz750 CFmoto 500 Ktm 250 Freeride
Kan tänka mig att det är 28:eek:r , om det är orginal gs1000. På gsx1100 som kom sen var ju smoothbore 33:eek:r da shit
Blitzen
Man kan göra så....
4 Jan 2005
Hindås med Goiting
GSX-R 7/11, EXC450
Ser ut som Mikuni VM33 eller VM29
"Mikuni VM33 assemblies were originally sold for racing applications or big-bore modified street engines. These carburetors offer the ultimate in top end horsepower and provide all the fuel your motor can use when under extreme loads. These carburetors also need tuning for each application in almost every case. We totally disassemble, clean ultrasonically and then by hand and replace any part that needs to be replaced. After reassembly, setting the float levels and bench synchronization , we jet the carbs for our stock test bike using pod air filters and aftermarket, baffled exhaust and road test. We verify the operation of the carburetors in a road test. You can either start with our baseline jetting or we will rejet these carburetors at no additional charge to your specifications. Our baseline jetting is #130 main jets, #30 pilot jets, 6DJ30-4 jet needle, 261 0-6 needle jet, .6 air jet."
http://www.wgcarbs.com/index.php?option=com_content&task=view&id=14&Itemid=29
http://www.cyclewareables.com/pages/mikuni_vm33mm_smoothbores/mikuni6.jpg
http://www.cyclewareables.com/pages/mikuni_vm29mm_parts_view/vm29carbview.gif
GubbLasse
28 Jun 2008
Ingarö, Stockholm
Mikuni VM 26 SS Smoothbore carbs as factory fitted to the GS 1000 SN..hitade jag på ett ställe
<micke>
#647, Supermoto S1.
20 Aug 2004
Blåsta
Cb 985 Café-racer bygge, SXS 300 -07 Motocross, Kxf 450 -09 Supermoto, Minimoto 49 cc
Aha, okej tack grabbar!
Är ju ute efter minimum 33. Men då kan jag alltså söka runt lite efter orginal gasare till Gsx 1100 då?
Hittade en Vm 29 (borrad till 33) brygga som jag är småsugen på, men vet inte riktigt. Tror nästan det blir för litet till min motor när den är färdig.
Ska på en iordninggjord Cb 900 -81 motor.
GubbLasse
28 Jun 2008
Ingarö, Stockholm
Nä ,orginal till gsx 1100 är cv gasare..(vakuuuum).men det fanns som trimgasare smoothbore 33 :eek:r,,de kan du leta efter, :)
Sena 60S intercom
Triumph Speed Triple 30 år
BMW Concept F 450 GS
EICMA 2024: Yamaha
Yamaha Tracer 9 uppdateras
EICMA 2024: Ducati
