Varadero är väl den enda långfärdshojen med 125cc.
Men man bränner utan problem 20+ mil med en crm/dt på en dag.
jag är ingen sån person som gillar att pilla med en 2 taktare vill helst ha en glidare då eftersom dom drar cirkus 0.25l / mil (enligt Bikez.com)
enligt dom har Shadown 11000 rpm
och intruder inte lika mycket...
General information
Model: Suzuki Intruder 125 LC
Year: 2006
Category: Custom / cruiser
Rating: 74.1 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.00 ccm (7.57 cubic inches)
Engine type: V2
Stroke: 4
Power: 13.14 HP (9.6 kW)) @ 10500 RPM
Torque: 9.80 Nm (1.0 kgf-m or 7.2 ft.lbs) @ 8000 RPM
Compression: 10.3:1
Bore x stroke: 44.0 x 40.9 mm (1.7 x 1.6 inches)
Fuel system: Carburettor. Mikuni BDS26
Fuel control: SOHC
Ignition: Digital electronic
Starter: Electric
Lubrication system: Wet sump
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Clutch: Wet multi plate
More details Consult a Suzuki repair manual.
Physical measures
Dry weight: 241.0 kg (531.3 pounds)
Seat height: 685 mm (27.0 inches) If adjustable, lowest setting.
Alternate seat height: 805 mm (31.7 inches) If adjustable, highest setting.
Overall height: 1,110 mm (43.7 inches)
Overall length: 2,240 mm (88.2 inches)
Overall width: 880 mm (34.6 inches)
Ground clearance: 150 mm (5.9 inches)
Wheelbase: 1,520 mm (59.8 inches)
Chassis and dimensions
Rake (fork angle): 31.7°
Front suspension: Conventional, oil damped, coil-sprung telescopic
Rear suspension: Twin shock absorber, adjustable spring preload
Front brakes: Single disc
Front brakes diameter: 275 mm (10.8 inches)
Rear brakes: Expanding brake (drum brake)
Rear brakes diameter: 130 mm (5.1 inches)
Speed and acceleration
Power/weight ratio: 0.0545 HP/kg
Other specifications
Fuel capacity: 12.00 litres (3.17 gallons)
Förstår inte en sak i denna instruktionen av Suzuki Intrudern och det är
''Power/weight ratio: 0.0545 HP/kg''
General information
Model: Honda Shadow 125
Year: 2006
Rating: 60.1 out of 100. Show full rating and compare with other bikes
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: V2
Stroke: 4
Power: 14.75 HP (10.8 kW)) @ 11000 RPM
Torque: 10.50 Nm (1.1 kgf-m or 7.7 ft.lbs) @ 8500 RPM
Compression: 11.8:1
Bore x stroke: 42.0 x 45.0 mm (1.7 x 1.8 inches)
Fuel control: SOHC
Ignition: Dual digital transistorised with electronic advance
Starter: Electric
Cooling system: Liquid
Gearbox: 5-speed
Transmission type
final drive: Chain
Clutch: Wet, multiplate with coil springs
More details Consult a Honda repair manual.
Physical measures
Dry weight: 146.0 kg (321.9 pounds)
Seat height: 680 mm (26.8 inches) If adjustable, lowest setting.
Ground clearance: 145 mm (5.7 inches)
Wheelbase: 1,530 mm (60.2 inches)
Trail: 122 mm (4.8 inches)
Power/weight ratio: 0.1010 HP/kg
Fuel capacity: 14.50 litres (3.83 gallons)
''Power/weight ratio: 0.1010 HP/kg''
Vilken skulle ni isåfall själva helst haft?
