Jag tror därför inte att ECU gömmer någon vassare tändkurva som ger mer effekt vid t ex 98 oktan, då hade nog rekommendationen varit just 98?
Hittade lite intressant läsning, eftersom jag inte kunde svara på de frågor jag ställde mig själv.
Ang. S1000RR's ecu och tändsystem och vidare användning av flera(?) mappar.
Tagit från:
http://www.webbikeworld.com/BMW-motorcycles/bmw-s-1000-rr/s-1000-rr-motorcycle-2.htm
"Engine Management With Cylinder-Specific Anti-Knock Control For Maximum Power And Performance
The S 1000 RR comes with the most advanced and sophisticated digital motor electronics currently available on a motorcycle. The software incorporated in this sophisticated BMS-KP (short for BMW Engine Management with Anti-Knock Control) is an in-house development by BMW Motorrad specifically for motorcycle applications.
Fully sequential, cylinder-specific fuel injection, integrated anti-knock control, ultra-fast processing of a wide range of sensor signals by the most advanced microelectronics, a compact layout, low weight and self diagnosis are the most important features of this sophisticated system.
And to meet the requirements of a supersports machine, the engine management unit comes on the S 1000 RR with an even faster central computer developed to an even higher standard and fully adapted to this unique machine.
Torque-based engine management takes a wide range of different parameters and criteria into account. The supply of torque and the sensitive adjustment of engine running conditions, for example, follow all kinds of requirements tailored to the rider’s needs.
The main parameter in controlling the engine is the amount of air drawn in determined indirectly through the throttle butterfly angle and the running speed of the engine. Taking additional engine and ambient parameters (including
engine temperature, air temperature, ambient air pressure) into account, the engine control unit, together with
control maps integrated in the system and appropriate correction functions, determines the ideal injection volume and
ignition timing.
Fuel grade is premium unleaded, that is at least 95 octane. And thanks to cylinder-specific anti-knock control, the power and performance of the engine may be raised to an even higher standard when running on higher-octane fuel."
