Tools!
Lokke
Bullshit Racing
Jakobstad, Finland
BMW R1200GSA -12, Suzuki GSX-R750 K3, Yamaha XV1100 -91
Lite info om verktyg på engelska. (gammal? ...igen?)
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate expensive parts not far from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in
their holes until you die of old age, but it also works great for
drilling mounting holes in fenders just above the brake line that goes
to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the palm of
your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease
inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you to
say, "Ouc...."
HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground
after you have installed your new front disk brake setup, trapping the
jack handle firmly under the front fender.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward
off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes
and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease
buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the end
without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that
your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under motorcycles at night. Health benefits
aside, it's main purpose is to consume 40-watt light bulbs at about the
same rate that 105-mm howitzer shells might be used during, say, the
first few hours of the Battle of the Bulge. More often dark than light,
its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last tightened 40 years ago by someone in Sindelfingen, and rounds
them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Gammal igen;
Alla har vi väl stått med en engelskspråkig Haynes Workshop Manual? Visste väl det... Och du undrar säkerligen ibland: "Vad MENAR de EGENTLIGEN?"
Här kommer svaren på det du alltid undrat!
Haynes manual translations:
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer
...........anticlockwise.
Haynes: This is a snug fit.(trång passning)
Translation: You will skin your knuckles!........on both hands.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you to read through the text before you start! Now, instead, you are looking at scarey photos of the inside of a gearbox, as a matter of going ahead too quick...
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out that pesky bayonet bit.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing. Then re-check the manual because this cannot
be 'lightly' what you are doing now.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it
up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, 'ikkle number... but you also thought the wiring diagram was a map of
the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Honda's are easy to maintain right... right? So you think
three Honda spanners has got to be like a 'regular bike's two spanner job. HA-HA!
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: ahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search in the dark corner of the garage For
whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are
looking at, then declare in a loud knowing voice to your wife "Yep, as I
thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much
harder.Once that sinking pit of your stomach feeling has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book but the thing you want to
do!
say, "Ouc...."
Nåt av det roligaste jag läst på länge!!! HA HA HA HA HA!!
Screenshot De flesta nav...
Pressrelease från Galfer: ...
Screenshot I kommande nu...
Ducati DesertX 2026
KTM firar 100 år av 6DAYS
