Tsunamin i Japan
Blanco
Glad påsk!
4 Oct 2004
Liljeholmstorget
Bmw gs 1200 Adv.
Det är tydligen rätt så kallt där, inte bra för överlevande som är fast. Men samtidigt så hindrar det förruttnelse som var ett stort problem vid tsunamin 2004
Wiseguy
Medlem nr.8 sen starten
Från Reuters
"The nuclear reactor is surrounded by a steel reactor container, which is then surrounded by a concrete building," Chief Cabinet Secretary Yukio Edano said.
"The concrete building collapsed. We found out that the reactor container inside didn't explode."
Japan earlier in the day warned of a meltdown at the reactor at the plant, damaged when a massive earthquake and tsunami struck the northeast coast, but said the risk of radiation contamination was small.
"We've confirmed that the reactor container was not damaged. The explosion didn't occur inside the reactor container. As such there was no large amount of radiation leakage outside," he said.
"At this point, there has been no major change to the level of radiation leakage outside (from before and after the explosion), so we'd like everyone to respond calmly," Edano said.
"We've decided to fill the reactor container with sea water. Trade minister Kaieda has instructed us to do so. By doing this, we will use boric acid to prevent criticality."
Edano said it would take about five to 10 hours to fill the reactor core with sea water and around 10 days to complete the process.
Edano said due to the falling level of cooling water, hydrogen was generated and that leaked to the space between the building and the container and the explosion happened when the hydrogen mixed with oxygen there.
zappen
Hepp
8 Jun 2004
Linköping
2*Yamaha
Nu är det inte 10 km utan 20 km evakueringsgräns som gäller vid Fokushima nr 1. /CNN
KGK
1200
1 Jan 2006
fjollträsk
KGK
svenskar får stöd att lämna landet.
Oroliga svenskar flyr Japan efter det förödande jordskalvet och den enorma flodvågen som orsakat tusentals dödsoffer. Kärnkraftsolyckan i katastrofens spår blev droppen för Hanna Myrling och Ola Olsson i Tokyo.
- Vi har bokat biljetter till söndagsmorgonen, och ska flyga till Malaysia, berättar Hanna Myrling.
Hennes sambo arbetar för Telenor Connections som stöttat paret i beslutet att lämna Japan.
http://www.svd.se/nyheter/utrikes/tusentals-svenskar-i-skalvets-japan_5998961.svd
KGK
1200
1 Jan 2006
fjollträsk
KGK
En av mina bästa vänner ligger och lossar olja vid ett raff utanför Sendaiar, de har satelituppkoppling ombord så även om all kommunikation i land är väck lider inte de av det, men inte ett ljud från honom. Det ser inte så ljust ut tyvärr. :död
hört nåt från kompisen, båt från Stena klara det bra.
Stena Bulk hade tre fartyg i området när skalvet och vågen drog in.
Ett av dem, Stena Chiron, låg vid oljeterminal i Yokohama och lastade brännolja när vågen kom.
- Vi hade först ingen kontakt med dem, men nu har jag talat med kapten ombord och han beskriver det hela som en omskakande upplevelse, säger Ulf Ryder, vd på Stena Bulk.
Varningen för tsunamin kom sent till befälet ombord på fartyget, men man hann förbereda sig bland annat genom att slacka på förtöjningslinorna och ha motorerna i gång.
Fartyget klarade sig och lämnade hamnen efteråt.
- Hon går nu till en kinesisk hamn och där får vi inspektera eventuella skador.
Magnif Bastard
nästan perfekt
19 May 2007
Vasastan
Familjepaus
Med tanke på våra resplaner får man hoppas att "the big one" dröjer minst 1.5mån... :gnissla FAAN, jag ska ju bada varma källor, klättra Fuji, dyka på Ishigaki och hinna klä ut mig till Geisha!!! :mad:
Från DN idag:
Seismologiprofessor Roland Roberts gör inga jämförelser mellan gårdagens skalv och det som utlöste tsunamin annandag jul 2004.
– Det skalvet var betydligt kraftigare och drabbade länder som inte alls har samma beredskap och infrastruktur som Japan.
– Det här är en stor jordbävning, men med måttliga dödstal så vitt vi kan bedöma i dag. Då fick också tsunamin större konsekvenser för stora områden långt från jordbävningens centrum. Bedömningen den här gången är att tsunamin blir betydligt måttligare där den når fram, säger Roland Roberts.
I snart 30 år har seismologer väntat på ett kraftigt jordskalv i närheten av mångmiljonstaden Tokyo. Gårdagens skalv kom för långt norrut för att vara det.
– Det här skalvet ligger alldeles för långt bort från Tokyo för det. Man väntar på ett stort Tokyoskalv, men det har gått över tiden. Ser man till historiska data borde det ha skett för 20–30 år sedan.
– Vilka konsekvenserna blir för hur framtida skalv i området ska uppträda är svårt att säga. Det kan skynda på det stora Tokyoskalvet, men det är heller inte säkert, säger Ari Tryggvason.
KGK
1200
1 Jan 2006
fjollträsk
KGK
området kommer vara instabilt ganska länge, skalv på 7.9 väntas
http://edition.cnn.com/video/#/video/bestoftv/2011/03/12/exp.freed.predicting.quake.cnn?hpt=C2
inte varje dag man får ett jordskalv på 7.9 på köpet av en semesterresa så du kan väl kalla det en äventyrsresa :tungan
KGK
1200
1 Jan 2006
fjollträsk
KGK
kan ju hoppas att de inte tagit i underkant.
Japans kärnkraftsorgan har bedömt olyckan i Fukushima som 4 på en internationell skala från 0-7, enligt BBC. Tjernobylkatastrofen 1986 rankas på samma skala som 7. Skalan utvecklades av FN:s atomenergiorgan IAEA år 1990.
Nivå 4 beskrivs som en olycka "utan betydande risk för omgivningen", enligt IAEA.
Incidenten på det svenska kärnkraftverket Forsmark år 2006, då en kortslutning i ett ställverk medförde att reaktorn fick snabbstoppas, kategoriserades då som en tvåa, skriver TT.
GuW
Version 1.1
30 Jul 2004
Nej
Ja
Det är ju jävligt konstigt att man i ett land som bokstavligt talat skakar sönder med jämna mellanrum törs satsa på och bygga nya kärnkraftverk, medans man i sverige är livrädda för riskerna.
Det fungerar ju uppenbarligen i Japan under värsta tänkbara förhållanden, vad är det värsta som kan hända här?
Att en mört fastnar i kylvatteninloppet?
Masonit
10 Jun 2003
Helsingborg
Ja.
Fungerar??? Ett kärnkraftverk med härdsmälta är knappast fungerande. Faran lär ju vara långt ifrån över. Tänk på dem som jobbar på kärnkraftverket. De lär ha strålningsskador. Hur många kommer inte att skadas vid saneringen...
\Masonit
Samme
Skrotsamlare
Öregrund
Suzuki GSXR 1000 K2, Yamaha FZR 1000 -89, Suzuki GSX 1100 -82 och en Ktm Superduke Gt -17
Ingen härdsmälta har bekräftats än och bara mindre, kontrollerade utsläpp av tryck har gjorts för att avlasta reaktorinneslutningen. Jag vill se siffror från officiellt håll på eventuella strålskador på personal innan jag ropar på vargen. Kontrollrummet är som regel försett med nödventilation så att de som kör verket ska kunna sköta sitt jobb.
Masonit
10 Jun 2003
Helsingborg
Ja.
Kontrollerade utsläpp? Du menar när reaktorbyggnaden sprängdes?
"A Jiji report says three workers have suffered radiation exposure near Fukushima nuclear plant" -Reuters.
Hoppas verkligen att läget har stabiliserat sig.
\Masonit
Johansson
Sporthoj Senior Member™
Gôtteborg
Aprilia Tuono v4r
Det värsta som kan hända är väl att elpriserna går ner när tillgången på el blir tillräcklig så vinsterna blir lägre för bolagen :gnissla
GuW
Version 1.1
30 Jul 2004
Nej
Ja
Näe, det värsta som kan hända är att tillgången blir god, priserna sjunker och staten därför får in mindre skatt.
Enligt någon svensk expert i morse efter "explosionen" så var det bara korrugerad plåt i överbyggnaden som blåste bort, en kraftig ångbubbla hade räckt för att blåsa bort den.
Fira motorcykelns dag 3 maj
Den 3 maj firas Motorc...
Motorcykelns dag firas 3 maj
Den 3 maj 2025 fi...
Triumph redo för terrängen
