Läcker, eller??
Engine liquid cooled single-cylinder 4-stroke engine
Displacement 644,03 cc
Bore x stroke 100 x 82
Compression ratio 11,7:1
Valve gear 4 valves / OHC, rocker arms with rollers
Engine lubrication pressure circulation trochoid oil pump
Filter system micro filter, flushable oil seen, magnetic screw
Starter E-Starter / Kick-starter
Decompression fully automatic / manual
Ignition Kokusan digital
Battery Yuasa YTZ 7S
Carburettor Keihin MX FCR 41
Exhaust system 2-into-1, twin manifold / nickel-plated, aluminium rear muffler
Fuel unleaded premium-grade gasoline (RON 95)
Transmission 6-speed
Clutch wet multi-disc clutch, operated hydraulically
Primary drive 29:78
Secondary drive DID X-ring chain 15:40
Frame 25CrMo4 tempered
Handlebar Magura aluminium, conified
Front suspension WP MXMA 4860-Husaberg Supermotard
Rear suspension WP PDS 5018-Husaberg Supermotard
Front/rear suspension travel 260mm / 287mm
Front brake Beringer 6 piston caliper, 310mm
Rear brake Brembo single-piston floating caliper, 220mm stainless steel
Front rim Behr 3,50x17"
Rear rim Behr 4,25x17"
Front/rear tire 120/60-17" / 150/60-17"
Wheelbase 1490 mm
Seat height/Ground clearance 870mm / 320mm
Tank capacity 9 litres
Dry weight 112 kg
![Husaberg_SM_04_700p.jpg](http://www.mcnews.com.au/NewBikeCatalogue/2004/Husaberg/Husaberg_SM_04_700p.jpg)
Primary drive 29:78
Wheelbase 1490 mm
Dry weight 112 kg
