Svenska Highland
Engine 950 cc, four-stroke DOHC, liquid-cooled, 60-degree Vtwin, 4 valves per cylinder, 11,5:1 compression
Engine lubrication Wet sump, double filter, pressure lubricated crankshaft, camshaft and gearbox
Power output 62,5 kW (85 hp) at 6000 rpm - max torque 104 Nm at 4000 rpm (tuning kit available for racing purposes)
Bore/stroke 95/66 mm
Injection/ignition i2 Highland integrated engine management system with ignition coils fitted directly on the spark plugs
Starter Electric
Electrical system 12 V, SEM 310 W, 12 Ah battery
Transmission 6-speed gearbox, lubricated mult disk clutch, Xring chain
Brakes, front 310 mm floating disk, Beringer six piston caliper
Brakes, rear 220 mm disk, with Brembo caliper
Front fork Kayaba
Frame and swing arm CrMo steel
Shock absorber Penske
Wheels Pirelli Super Corsa 120/70-17" front and 160/60-17" rear, Excel aluminum rims with Talon hubs
Seat height 720 mm
Wheelbase 1 400 mm
Fuel capacity 10 liters
Weight / Top speed 129 kg / +200 km/h
