DC hub: sporthoj.dyndns.org
toca1 skrev:
varför får man inte köra oDC på hubben??? jag vett att det bara är att byta men jag vill inte :-(
oDC är en gammal och förlegad klient som inte uppdaterats på ett år och några månader.
Kommer det en uppdaterad version så kommer de troligen att släppas in.
Allt fungerar mycket bättre om alla använder de senaste versionerna! :tummenupp
http://dcplusplus.sourceforge.net <DC++ 0.670>
-- 0.670 2005-02-04 --
* Fixed an issue with international formats of float numbers (also fixes UDP port setting)
* Fixed a minor crash log output address issue
* Split off color and sound to a new page (thanks ullner)
* [bug 359] Fixed an issue with negative search terms (thanks naga)
* Added option to filter TTH results in search spy (thanks joakim tosteberg)
* [bug 184] Updated log functionality to allow users to customize log filenames (thanks naga)
* Fixes to log edit function (thanks naga)
* Added possibility to filter all searches without tth (thanks naga)
* More preferences splitting (thanks ullner)
* Small socket fix (thanks tremor)
* Search tab goes bold if set to (thanks naga)
* Hopefully fixed an UPnP crash
* [bug 302] User commands in file lists (thanks joakim tosteberg)
* ADC url's clickable (thanks naga)
* Improved search timer to avoid spamming hub (thanks naga)
* Redid some of the hash storage code, should be slighly more efficient
* [bug 94] Share is cached for faster startup
* Temporary targetnames are now filled in when download starts, not when item is added to queue,
which makes temp target dir changes happen for current queue items as well, plus we get a huge
memory save on huge queues.
* [bug 363] Added "Remove All Sources" to queue (thanks izzzo & garg)
* Queue menu items greyed out when there are no items (thanks izzzo)
* Fixed a crash with certain empty lists (thanks garg)
* Added "restore all" to undo "minimize all" (thanks guitarm)
* Added optional pm history (thanks trem and ullner)
* Better log file managment (thanks trem)
* [bug 412] Fixed a queue count issue on removal (thanks ullner)
* [bug 9] Fixed a queue move issue (thanks paka)
* [bug 20] Fixed upload auto-slot granting (thanks naga)
* Redid adl search to accomodate for partial list browsing (thanks garg)
* Added initial ADC file transfers support
* ADC hub connectivity improved
* Fixed unnecessary COM initialisation (thanks garg)
* Some linux compile fixes
* Added readd all sources (thanks garg)
* Fixed a deadlock when closing hub windows (thanks trem)
* Added user ip logging in up and downloads (thanks ullner)
* Small spy frame fix (thanks garg)
* Small pm fix (thanks garg)
* Added password warning for n00bs (thanks sed)
* Help file updates (thanks ullner, garg)
* Probably fixed the list redownloading bug
* Hash index format change (as a side effect, it's very easy to find dupes
in the new format, someone should make a tool)
* Download manager changes in preparation for partial list browsing and other
ADC features
* Improved efficiency for small files (<=64KiB) in the hash storage
* Added advanced resume that detects and tries to repair rollback inconsistencies
using tiger trees
* Fixed a rare invalid zlib decompression error
* Autosearch and automatch queue is now done by tth only (!) (thanks garg)
* Automatch search done by tth only, should make things slightly faster
* Search for alternates automatically uses tth if available (thanks garg)
* Lowered compression level so that uploads will take less cpu
* Added exact file size to directory listings (thanks paka)
* Remove confirm fix (thanks trem)
* Added option for the new tab select behaviour (thanks trem)
* [bug 116] Added possibility to download to temp folder on the same drive as target (thanks sed)
* Fixed user command string for file list context (thanks sed)
* [bug 290] Added more correct escaping of search strings (thanks sed)
* [bug 432] Fixed download directory for adlsearch matches (thanks ullner)
* Some UPnP fixes (thanks nils maier)
* ADL Search byte prefix fixes, might screw up your adl search settings on first load (thanks ullner)
* Linux download path fix (thanks jens oknelid)
* Added purge button for search history (thanks sulan)
* Added column reorder to file listing (thanks ullner)
* Fixed alt source download starts (thanks paka)
En dum fråga kanske.....men va är oDC :confused:
Edit:
Hmmm...glöm att jag frågade...fick svar nu...
Betyder uteblivna PM-svar att du inte hunnit/orkat svara eller att man inte är välkommen på hubben?
Mvh, chrilla
Mvh, chrilla
Ja kanske det...
Vet inte varför just du inte fått svar men PM som ser ut som:
"Öhh lösenordet te hubben!! vad är det för adress? typ.."
brukar jag inte bry mig om.
De som orkat läsa någon tråd om hubben skickar ett PM som har all info brukar prioriteras i alla lägen:
"namn: Kalle
pwd: Anka
Jag har BBB 10/10 och delar ca 250gb."
Känns lite som att kvaliten på hubben har sjunkit lite med alla nya som kommit till.
Med hastigheten man får av en del skulle det ta minst fyra månader innan man får hem en film.
Netlimiter rockar typ jättefett.. :arsele
zykl0n skrev:
Ja kanske det...
"namn: Kalle
pwd: Anka
Tror att jag gett all den infon i mina PM... :va
Har Sunet 10/10 men delar bara ca 30 GB (kanske är förklaringen) :confused:
Skickar ett nytt PM...
Jaha, nu är det dags att rensa konton. Ni som vet med er att ni inte varit inloggade på hubben i år, och vill ha kvar era konton bör logga in inom kort. Om ett par dagar försvinner alla konton som inte är använda i år.
Lite flyttskador på hubben just nu.
sporthoj2.dyndns.org - bör fungera :tummenupp
[reg only]
sporthoj2.dyndns.org:411
sporthoj2.dyndns.org:929
Får upp det här meddelandet hela tiden när jag försöker gå in på sporthojshubben :confused:
R0B0T> YnHub version: 1.033 produced by Yoshi and Nev.
<-CORE-> Current user count: 24 after 2:18:07:10 uptime
<-CORE-> Current sharesize is: 2.89 TiB
<R0B0T> This is a registered users only hub
*** Redirect request received to a hub that's already connected
*** Disconnected
jag kommer inte in på sh hubben längre :confused: får bara upp :
*** Connecting to sporthoj.dyndns.org...
*** Connected
<.:Bemvindo-Bot:.> YnHub version: 1.033 produced by Yoshi and Nev.
<.:Bemvindo-Bot:.> Your nickname is too short, please change it and reconnect
*** Disconnected
vad e felet ?
Va fan..............................
*** Connected
<.:Bemvindo-Bot:.> This is a registered users only hub
*** Disconnected
*** Connecting to sporthoj.dyndns.org:929...
*** Connected
<R0B0T> YnHub version: 1.033 produced by Yoshi and Nev.
<-CORE-> Current user count: 32 after 2:22:23:24 uptime
<-CORE-> Current sharesize is: 3.51 TiB
*** Disconnected
*** Connecting to sporthoj2.dyndns.org:929...
*** Connected
<-CORE-> Current user count: 3 after 22:41:55 uptime
<-CORE-> Current sharesize is: 1.04 GiB
*** Disconnected
Sharesize 3,51Tib / 1,04Gib :3freak
*** Connected
<-CORE-> Current user count: 35 after 3:00:02:38 uptime
<-CORE-> Current sharesize is: 4.23 TiB
*** Disconnected
*** Connected
<-CORE-> Current user count: 3 after 1:00:21:12 uptime
*** Disconnected
KODD! :huvet
Precis som zykl0n har skrivit ovan är det port 929 som gäller, alltså går ni in och ändrar bland era favorithubbar och skriver dit sporthoj.dyndns.org:929 som adress. Detta gäller alltså er som redan har konton, övriga får ansöka som vanligt
Zyklon, har du mycket på G nu ?
Har skickat mina uppgifter för ett par dagar sen men inte fått nåt svar :confused:
Screenshot I samband med...
Pressrelease från Galfer: ...
Screenshot I kommande nu...
