Haynes manual föklaringar
BMW R90s
5 Apr 2003
Linköping
BMW 1200GS
Det här hör kanske hemma bland kackel, moderatorn får väl
flytta den dit om han vill.
Hej!
Alla har vi väl stått med en engelskspråkig Haynes Workshop Manual? Visste väl det... Och du undrar säkerligen ibland: "Vad MENAR de EGENTLIGEN?"
Här kommer svaren på det du alltid undrat!
Haynes manual translations:
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer
...........anticlockwise.
Haynes: This is a snug fit.(trång passning)
Translation: You will skin your knuckles!........on both hands.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you to read through the text before you start! Now, instead, you are looking at scarey photos of the inside of a gearbox, as a matter of going ahead too quick...
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out that pesky bayonet bit.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing. Then re-check the manual because this cannot
be 'lightly' what you are doing now.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it
up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, 'ikkle number... but you also thought the wiring diagram was a map of
the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Honda's are easy to maintain right... right? So you think
three Honda spanners has got to be like a 'regular bike's two spanner job. HA-HA!
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: ahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search in the dark corner of the garage For
whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are
looking at, then declare in a loud knowing voice to your wife "Yep, as I
thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much
harder.Once that sinking pit of your stomach feeling has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book but the thing you want to
do!
Ravetrancer
Now even more badass!!!
R1-01, R1-04, Husa 650-04, Husa 600-98, cr125-98
Asgarvar nu, hahahahaha :D
Kan du inte översätta den till svenska.....så fler fattar den......
Mookie
Har katt.
7 Apr 2003
Götet.
VTR1000 firestorm, Svart edition. SRZ660, mookie edition. Kinesisk minimoto, skitkul edition.
Zigge
Honda VFR 750 F -91
Haha! :tummenupp
Många roliga men fastnade speciellt för
:D
UltraMarine
Stockholm/Vasastan
Inga märkvärdiga saker
Det värsta är ju att det STÄMMER!!!
Speciellt "See chapter 7" och då får man otroligt avancerad förklaring på nåt helt annat...
EICMA 2024: Yamaha
Yamaha Tracer 9 uppdateras
EICMA 2024: Ducati
Honda ICE Concept
EICMA 2024
EICMA 2024: KTM
