Ska du stressa vinterbilen lite?
Kolla den den här länken för schyssta "performance parts"!
http://www.kalecoauto.com/
Att man orkar göra ett sånt skämt....Cujo skrev:Allvarligt talat, när bytte du blinkersvätska senast?
"-High Quality Synthetic Blinker Fluid-
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, blinker fluid should be changed every 150,000 blinks! KaleCo high quality synthetic blinker fluid meets the highest D.O.T. standards! KaleCo blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause! KaleCo blinker fluid will not lose its viscosity, even in the most extreme situations! Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car." Only $5.99
Eller vaför inte satsa på marknadens bästa "Piston Return Spring". Endast $25 styck, (Du behöver en till varje kolv).
Cujo skrev:Ska du stressa vinterbilen lite?
Kolla den den här länken för schyssta "performance parts"!![]()
Innehåll Bike powered by... |
Shelby Turner, klar för GGN
