Ktm 690
peny
7 May 2009
tokstan
07, ktm 690
någon som vet hur man justerar APS sensorn utan PC och kabel alt
har PC och kabel och vill göra det för en slant?
ps har kollat med verkstäder men alla har typ 4 veckors väntetid
samuel86
23 Mar 2009
Örebro
KTM RC8 - 08
Hallå!
Här lite info om Wings. Har mailat med dom.
Håll till godo.
Denna sida använde jag mig av.
wings-silencers.co.uk
Pictures and detailed description can be seen on www.wings.si
Here are the prices for KTM690 Supermoto/Supermoto R/Prestige (07- ):
- oval or NOS* Titanium mufflers (pair) without carbon end caps____498.-EUR
- oval or NOS* Titanium mufflers (pair) with carbon end caps_______548.-EUR
- postage (additional)_________________________________________21.-EUR (it takes 4-8 days)
Clamps, bolts and gaskets needed for the mounting are included.
You will also get two different sets of dB-killers (in the price included) for the sound tuning:
-small (slightly louder than original)
-large (louder).
They can easily be removed for sport riding.
How to purchase WINGS products?
WINGS silencers can be ordered directly from us (producer). That's the guaranty for the lowest prices.
There are two paying options:
-PayPal
-Bank transfer
If you prefer PayPal just reply to this E-mail and tell us that you have chosen PayPal, exactly which mufflers do you want and which KTM bike do you have. Than wait until PayPal will send you a form to fill in and make the payment. Mufflers will be sent to you within a few days after receiving the payment confirmation.
Paypal is safe and easy way to make an online payment using your credit/debit card even if you are not a PayPal member (learn more https://www.paypal.com/ ).
If you prefer bank transfer just reply to this E-mail and tell us that you have chosen bank transfer, exactly which mufflers do you want and which KTM bike do you have. We will send you the bank account details for the payment. Mufflers will be sent to you within a few days after receiving the payment.
I will gladly answer any additional questions you may have so please don't hesitate to ask.
Best regards,
Gorazd Marovic
WINGS silencers
*NOS = Non-Oval Shape (PAT. No.: M-200650019 and 633557-0001).
WINGS logotype and wings symbol are registered trade-marks.
Jag gav 532 euro inkl frakt, bra tyckte jag.
Jätte nöjd med dom piporna :)
Supermoto
Racer has-been...
Örebro.
| FE501 -14 sumo/enduro | CR500 -89 | FS1 -85(?) | ZZR 600 -93 "ratbike" | 350Freeride -12
Såg att GPR hade kommit ut med nya pipor till 690. Någon som hört nått om dom? http://www.mcweb.se/default.aspx?main=ListProducts.aspx&cat=1189
Blit det någon märkbar skillnad om man bara sätter på ett slip-on om man jämför med ett helsystem?
Akra helsystem vs. akra slipon = NOLL skillnad i kraft. Testade själv ett par gånger längs långrakan på Knutstorp förförra helgen samt på GÅsen förra året.
Helsystemet är våldsamt mkt läckrare i min ögon men kostar såklart en bra slant mer.
R1 racer
Stick i ögat!
8 Mar 2003
Pannkakslandskapet
En fet en!
Men du beställde endast ett slip-on? gött ljud eller? svår monterat?
Behövs mappning vid byte av endast slip-on?
Wings rockar :tummenupp. Tycker de ser bättre ut än Akrapovic burken och kvaliten är den samma.
Behövs inte mappas med enbart slipon enligt Wings info blad man får med,annars rekommenderar de Akrapovics mappning om man gör fler förändringar som tex öppnar upp luftburken osv.
Supermoto
Racer has-been...
Örebro.
Jag hajjar inte hur ni kan tycka två burkar är snyggare än en, dessutom tyngre :3freak
För min egen del väger nog hela mitt system, med två dämpare, lika mkt som EN av originaldämparna. Visst skulle då såklart ett system med bara en burk väga mindre men då blir ljudet högre om man vill bibehålla samma effekt. I mitt fall är priolistan, i ordning; ljud, effekt, vikt. Därför dubbelsystem i titan. Dessutom får inte jag tävla med annat än akra så valet är rätt enkelt :D
Dessutom är dubbelakrat löjligt snyggt :yoparty
Fatoslocos
29 Sep 2008
2006, Triumph Daytona 675
Wings
Hur är passningen med Wings systemet? är det helsystem man beställer eller hur funkar det? vad menas med öppen luftburk?
Va betalade du för ditt?
R1 racer
Stick i ögat!
8 Mar 2003
Pannkakslandskapet
En fet en!
De har och tillverkar endast slipon.
Öppen luftburk,locket av,KN filter,eller att man gör några några öppningar i luftburken så att hojen andas lättare
Lindquist
TeamLindquist.se
20 Mar 2009
Big City
690 SMC-R
Har du tagit av locket och satt ditt ett kn filter? blev det nån skillnad isf? Räcker det met att sätta ett vanligt rakt filter som täcker där locket satt?
Fatoslocos
29 Sep 2008
Wings
Hur betalde du? via bank konto eller paypal?
Ingen risk att man blir lurad? Så det behövs ingen mappning då?
leffo
17 Aug 2007
ja
man betalar via paypal, och man ska enligt wings mappa om hojen om man kör helt utan db-killers, vilket är att rekommendera :tummenupp
<-- kör med wings, K&N och utan db-killers
R1 racer
Stick i ögat!
8 Mar 2003
Pannkakslandskapet
En fet en!
Jag gjorde en vanlig överföring,visst chansning då jag inte visste mycket om företaget men bara hört goda ord.Det funka perfekt utan några problem.
Japp det du skriver ovan är att rekommendera enligt wings om man kör utan db killer och andra modifieringar.Oavsett vilket så hade jag mappat.
Jag kör med luftburkslocket av men använder mig av orginalfiltret.
Där är delade meningar om KN och diverse eftermarknadsfilter om att de trots allt släpper igenom dammstoft när oljehinnan på filtret är fullt av fint damm.
Däremot kan man få ut lite fler hk om man bygger/tar bort luftburken helt och trots allt kör med något eftermarknadsfilter direkt på insprutförgasaren.
Lindquist
TeamLindquist.se
20 Mar 2009
Big City
690 SMC-R
Jag betala direkt till hans konto, inga problem. var 1 månad sen
:tummenupp
Så om jag förstår dig rätt så att du 2 st orginal filter där? Hur har du gjort för att få det tätt där locket satt? lr beställer man ett som passar just där? Och har du märkt någon skillnad? går den bättre då?
Fatoslocos
29 Sep 2008
Tänkte göra en beställning nu. Va e skillnaden mellan OVAl or NOS* (det är väl oval eller inte oval?) ser dock ingen bild där man kan se skillnaden?
Så vilket är snyggast?
BMW R 18-modeller uppdateras
Screenshot BMW R 18 och ...
Fiffiga touringprylar
Uppdaterad KTM 790 Duke
