Me neither. Here's what they list:
Service Code Table
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor (EX) malfunction, wiring open or short
24 Speed sensor malfunction
25 Gear position switch malfunction, wiring open or short
26 Camshaft position sensor (IN) malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
37 Steering lock unit communication error
38 FI ECU communication error
46 Fuel pump relay malfunction, relay is stuck
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
59 Valve timing abnormal
62 Subthrottle valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
65 Oil control valve solenoid malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
68 Steering lock unit malfunction, wiring open
83 Oxygen sensor #2 inactivation, wiring open or short (Equipped Models)
87 Steering lock unit identify authentication Error
88 FI ECU identify authentication Error
Notes:
