Cambike eller Sportscam hjälmkamera?
  • Antal röstningar
    0
duccen900ss
Sportscam.se 4 life!
25 Jul 2003
Ducati 848, Ducati Multistrada & KTM 400EXC
De var inge vidare fräs i den där...... Har du några andra funderingar på någon annan?
Det lutar nog mer åt en mediainspelare med 30GB hårddisk just nu, blir ca 13 timmar inspelat material i HÖG kvalité med den! :tummenupp
Ripper
13 Oct 2005
Asås
CRF250R
Klarar en hårddiskinspelare att monteras på styrkronan/tanken eller måste man ha en fannypack?
Vad har vi för alternativ på mediaspelare med video in?
Irocc
26 Apr 2007
Malmö
Honda
Någon som har erfarenheter av PV-500 :an ?
Features:
- Super high resolution: The ability to record at 720x480 pixel resolution directly onto an SD card up to 4Gb, providing from 70 (1Gb) to 280 (4Gb) minutes of recording storage space.
- Power to camera supply: Through the AV-In socket on the unit, 5v output can be provided providing enough power to power directly a covert pinhole CCD camera.
- High capacity battery: The unit uses the 1100mA/3.7V mobile phone rechargeable batteries ensuring it is easy to extend the battery life of your unit
- Multiple recording modes: These include motion detection
- Tamperproof frame counter: Each frame contains a watermark ensuring that video evidence is admissible in court
- Smalled DVR in the world: The unit is small and compact in design, making it ideal for covert surveillance
Technical Specifications:
- Display: 2.4" TFT LCD
- Video Input: NTSC/PAL standard
- Video recording mode: Auto/Manual/Motion Detection/Schedule
- Resolution: 720x480 pixels @25~30fps max
- Memory type: SD (up to 4Gb)
- Recording time: 65 minutes / 1Gb SD card
- Audio recording: Yes
- Video recording: Yes
- Audio / video out: RCA 3-in-1 AV output
- PC interface: USB 2.0
- Camera power supply: DC 5v / 500mA
- Low power alert: Yes
- Power supply: DC 5v
- Operating current: 650mA
- Battery type: DC 3.6V / 1Amp Lithium Ion battery
- Battery life: 60 minutes
- Dimension: 80x52x22mm
- Weight: 91g with / 68g without the battery resp.
The recording package includes:
- PV500 DVR
- A/c Adaptor
- USB cable
- Installation software and manuals
- AV cables
- Belt pouch
- IR remote control
- Storage case
- Spare battery
Den verkar liten och nätt.
SP3-martin
mohaaaaaaaaa
11 Oct 2005
Speed Triple 06a, Ducati S2R 06a, MT-01 05a, såld
Ville bara tipsa om ytligare en kamera/videokamera/DVR
den är allså utrustad med AVin/utgång.
Finns hos www.teknikmagasinet.se
Aosta DV680 1499:-
Artnr760049
"Digital videokamera som du med fördel använder på semestern, fester och födelsedagar. Det lilla formatet gör att den lätt kan bäras i t.ex. en kavajficka eller handväska. Skärmen är på 2,5" och vridbar i 290°. Inspelning sker direkt till MPEG4 (VGA, 30 bilder/s). När det gäller stillbilder är DV680 minst lika bra som en "riktig" digitalkamera. Den har t.ex. 6 Megapixels upplösning, blixt och flera motivprogram. Tröttnar du på att filma/fota kan du spela spel eller lyssna på MP3-musik i de medföljande hörlurarna. Uttag för AV in/ut. 32 MB inbyggt minne samt SD-minneskortplats. Kamerans funktioner kan även styras via en medföljande fjärrkontroll – utmärkt när du visar semesterbilder och -filmer! Mått 105x60x28 mm. Vikt 115 g. Lev inkl batteri, laddare, USB-kabel, AV-kabel, ministativ, fodral, fjärrkontroll och programvara."
    44.1 KB · Visningar: 58
cubic
nothing beats cubic inches
23 Jan 2004
2013 KTM 350 Sixdays, 2011 Triumph Daytona 675
Tråden har ju funnits ett tag nu, någon som har köpt ngn kamera och vill dela med sig av erfarenheterna?
Fürsten, du har ju skrikit dig blå i den här tråden :D , har du ngr exempel-filmer man kan få glana på? Eller har du prylarna hemma så man får klämma och prova lite?
Om man kollar jämförelsen mellan en DVR och en kamera på Helmetcamera.com så det mest ut som det är skärpan som skiljer, men dem anger inte vad för utrustning som används förutom deras DVR...
DVR känns smidigast, men vill inte att det ska se ut som webcam från -84...
duccen900ss
25 Jul 2003
Sportscams grejer finns numera att klämma på i Ducati Stockholms butik på Frejgatan! :tummenupp
GSXR1100R
The older i get the faster i was
8 Mar 2003
South Sweden
Gammelgixxer, Kawwaräcer 600, KTM Adventure, KTM Elduro
Man kan montera kamera eller HD inspelare på ett kamerafäste.
duccen900ss
25 Jul 2003
Bra att veta!
Du har inte hört något om vibrations problem med dem?
Jag kanske tar och beställer en när jag får hem den senaste "demospelaren" (med hårddisk) ifrån asien... :tummenupp
Eller man kanske skulle ta och bli återförsäljare?
Mvh: Joakim Lundin
www.sportscam.se
duccen900ss
25 Jul 2003
From idag sänker Sportscam priset på kompletta hjälmkameror till otroliga 1695:-
Tänk på att du även kan köpa dessa i Stockholm! :tummenupp
Santo
Fuck You Burnout
17 Dec 2003
R1 2007
Tjoho! Ska fn aglida ner till Duccebutiken o kolla... måste mara slänga in en maskin tvätt först. Jävla förbannade fredagsnöje :mad:
Uppdaterad KTM 790 Duke
